Can somebody please help me find the starter on my 2001 Infiniti g20
I've looked at all the threads and can't seem to match it with what I'm looking at
So far the car is jacked up. I've removed the battery and intake box
I've looked all around for this y-bracket and starter but can't seem to find it
your way off man.
you had to take the intake off to get the bolts that hold it on pretty much at the top of the tranny stand by the driver tire and follow the tranny down to the right and reach behind and if you know what it looks like you will find it by feeling.
if you havent realized its a pain in the ass
its kinda dark outside now; ill continue tomorrow... Am i supposed to loosen the two bolts in the 2nd pic, which is near the driver side? and then look for it near the firewall above the passenger side axle?
The 00+ does NOT have the Y bracket.... the starter is on the back of the motor where the transmission meets the engine on the DRIVERS side of the car, above the axle and below the intake.
You have to remove the intake to access the two bolts that hold the starter in place. The two bolts in the first picture look correct.
Because of how the starter is designed you have to take it out, and install it from below the car. Its a pain in the ass but it IS doable with one person (I've done it twice). However a second person is helpful to screw the bolts in while you hold the starter in place from underneath the car.
Well I ended up finding it much easier when the sun was out... but how on earth did anyone do this with a regular jack and stands?? my hand can barely get in there, let alone wiggle the rusty piece of crap out of there... my ass was freezing and there was no way i'd be able to do anything at all other than bend my wrist and poke at it... the jack wouldn't go any higher..
lol, i just ended up putting everything back together and dealing with trying to start it with 5-10 turns of the key before it fires up... guess ill look for another starter before attempting it again.. or finding a mechanic to borrow their lift
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
