1 - 8 of 8 Posts
where can I get a camber kit for a 93.5 G20. Also is it normal for the CV boots to tear appart at 82k miles? both at the same time ? Can the articulation of my lowered suspension tear the boot? I have B+G springs with KYB gr-2's, only about 1.5 inches lower. Also what do you guys think of the camber adjusters below? How do they work? is there welding involved ?
http://www.ingallseng.com/parts/3541PR.htm
Thanks
The only place I've seen with one is a place in New Zealand.
http://www.prestigeautomotive.co.nz/
I couldn't find them quickly, but they are the only place in the world that I've seen a front camber kit for the P10/P11. Nice folks who know the Primera.
That could do it, but I would be suprised if 1.5" drop would. My car has been on that drop for over a year with no problems and many other folks have been OK with that. Strange. Probably related somehow though.
They are "crash bolts" that only work with struts. Therefore, they would only work at the back of the P10 and wouldn't work anywhere on a P11. We do not have struts in front.
Actually I posted the bolts becuase I'm still having my tire rub on the lower spring seat of the rear strut. Do you think this is a good solution ? I do have a guy at stillen who can get front controll arms that are adjustable, made in Japan I believe for the P10. The price is hefty at $380 that he quoted me but may be negotiable, especially with a group deal.
I would personally be very weary of this offer. The link that Geo provided is the only one i know of who makes these parts. Stillen is probably trying to sell you their 300zx parts which are very similar, yet different enough to where they wouldn't work for a G20.
Also, if your tire is rubbing on the strut I would be inclined to say it's either too large of a tire or a bent suspension piece. The tire/wheel shouldn't move in relation to the rear strut with a change in camber. Changing the camber should move everything equally, as they are all connected together.
The Upper controll Arm from Stillen is actually I believe from JIC, and after checking it is for a G20. As far as my rear camber goes, in a strut situation, it will effect the rubing. My wheels are 17x7 with 40mm offset and tires are 205/40/17's. There is no way this combo shoul rub, and the syspension is not bent since I just put the GR-2's in and checked yesterday for any abnormalities. This is a really puzzling situation since no one on here seems to have much of this problem.
simple rubbing solution: 1/4 inch or 1/2 inch spacers and roll the rear fenders. Thats what I got to get my 17x7.5" wheels w/ 215/40/17's to ride perfectly.
As for changing the front contol arms to aftermarket ones. How does this affect the suspension??
Discussion Starter #8
The front controll arms would be adjustable so your wheels would be correctly cambered and most likely stick out more since it pushes the top of your wheel outwards.
1 - 8 of 8 Posts
