1k for a used trans sounds reasonable to me. $800 for a 2000+lsd trans is cheap and the remaining 2-300 for labor is also cheap considering its probably a more than 4 shop hour job to replace a trans. honestly i would go with a used trans over a rebuild unless you REALLY trust the mechanic doing the rebuilding. trans issues in p11 are not very common so a used trans should be fine.
