found it thanks
The two bottoms are Coolant lines, the small vac nipple was the question. I currently have it hooked to the service port under the brake booster. Chime in if I am incorrect. I did feel sheepish when I realized I had the fuel lines crossed. Noob mistake. Thank you for trying to help! It runs smooth now except for all the slop in the drive train which I think is associated to the motor mounts and shifter bushings. I will make the lower mounts semi-solid and see if it helps. Wheel and tire combo on this car is garbage and that will change soon. I still have to relearn the throttle body iirc, and I will check the timing, think its a tad retarded. Just glad to have my beater back.i think those are coolant lines to the egr. i would double check the routing of the fuel lines and make sure the send and return lines arent switch and then do what the fsm says to do if a bad fuel pump is suspected.
