For the past couple months, my P11's rear window switch gets stuck into position if someone presses it down. I usually togggle the switch around until the window goes back up and it's fine.
Last night, the window went down and wouldn't go back up no matter what. I happened to have a new switch handy, so I swapped it out, but apparently that did absolutely nothing.
All the other windows work fine, so it's not a fuse or anything. I took off the panel to try and check connections or whatever, but everything seems to be in place. No weird noises...actually no noises at all. Do I need a new motor here? I'd rather not take it somewhere, but I want to be sure I'm replacing the needed parts. Not to mention it's rainy season here in FL:*(.
Any thoughts will be appreciated....thanks.
