Okay here it goes....I have a low port SR20 on my 99g20t.I need to resurfs the heads.Cost is about them same as a JDM motor.So What do I have to do
to convert a high port over to a low port.Can I just drop the block right in?
-Jesse-
G20 Junkee
You will need to extend some wires but the motors are interchangeble
New head - ALREADY?
Why do you need your head done already? Did you overheat you engine and blow the headgasket? or did a mechanic just TELL you your head is bad?
It's possible, i am currently performing the swap. Thers a couple things you'll need to do though. If you swap a JDM engine you have to remove the egr system or try and set up a fake one to trick the ECU or you'll get codes. Or you could have your ECU reprogrammed. It's not the easiest thing in the world, but its not too hard, as long as you are good at figuring little things out. If you ahve any questions feel free to PM and i can help you out.
