1 - 7 of 7 Posts
Automotive Design Concept
what is the differance between High Port/ Low Port motors ?, and what do i have on a 1996 motor?
You've got a lowport. I beleive on a lowport the injectors are below the engine block and on a highport they are above..
Used to own a P10
Below/above the throttle body, not the block.
It's all about the intake and how the ports flow through the head to the valves.
A high port has the intake low down behind the engine and loops up and back down so the fuel/air enter the head high up and flows downwards to the back of the valves.
On a low port, the intake is high and then loops down to where it meets the head. The fuel/air flows straight into the head then down to the back of the valves.
As above, you have a low port.
Used to own a P10
what one do i have and which one has the advantage?
1 - 7 of 7 Posts
