lately my g will rev to about 1200 when im at a stop or actually more acurate about 1000 then it will drop to about 500 and die. it would do this every now and then but it does it now about every time i come to a stop, could it be a bad sensor or fuel pump????
help please thanks
matt
96 g20
theres a bunch of other posts about this same problem on this site (and on se-r.net), but when this happened to me i took it to the dealer, and they 'cleaned the air flow regulator valve' for $110, which fixed the problem.
Well I had a similar prob...you might want to look into:
1. See that all your intake components are tight.
2. check your Alternator
3. Check your timing
4. Check ignition wires..
And as for this link i was checking if i know how to post a pick..
I am willing to bet that if you read this:
http://www.se-r.net/engine/troubleshooting_guide/tuneup.html
you will be able to find the problem. Or atleast eliminate others.
Hope that helps.
only $1.29
i took a trip down to autozone and bought a can of carburator cleaner and cleaned out the AAC, and so far that seemed to do the trick. thanks
matt
96 g
