What are the differences between the one for the 99 G20 and the one for the 2000-2001 G20?
And if anyone knows for sure, which one should I be using on a '98 J-Spec Primera?
If I remember correctly, b-b00gie did a write up about it, He did not have to change his batery when installing the CAI on his 2000 g20, even if Hotshot states in their website you will need to do that.
I've also seen the battery turned SIDEWAYS in the engine bay, to accomodate a HS CAI. I don't know if the battery was smaller than OEM, but SR20Dev had turned some B14 Sentra's battery 90 degrees so that it was longitudal in the engine bay, and the HS CAI passed behind it.
