1 - 13 of 13 Posts
A bird pooped on my car and i cleaned it up but there is some sort of stain on it probably caused by the acid from the poop. How can i remove this? Is there some special chemical or cleaner i can buy from an auto store?
hmm. that blows. try a very very fine sand paper and lightly wet sand the area that will get rid of any stain and even out the cleacoat a bit there but so much that irs gonna leave a weir lookin spot.
Good advice, just don't burn through the clearcoat (don't over-do-it). Aftwards, the compound will help to buff it back to a shine... sometimes just the compound alone will help to get rid of it (without the wet-sanding)... hope that helps.
o shit! i had no idea bird shit does that to ur car. i have been leaving it on cuz i was too lazy to wipe it. its hella disgusting. its not like i have one spot but all over the roof, hood, windows, and trunk.
Yep, even wiping off the birdie shyte with water will put the acid in the dried material back into solution.
Get rid of it ASAP. I find that those touch free car wash things that use really high pressure sprays do a good job of removing it.
1 - 13 of 13 Posts
