1 - 2 of 2 Posts
I was just curious. Under normal running conditions (over 10 minuates driving), what does your G's engine temperature gauge show? Pointing to the middle? (mine is) Is this normal? I remember the engine temperature used to be a little lower.
Radiator fans didn't kicked in at this moment. When will the radiator fans run and how do I know that? I feel like my engine temperature is a bit high.
Thanks.
My temp gauge is about half way. Don't worry. As long the gauge doesn't go up all the way then there should be little to worry about. According to the maintenance schedule, the coolant is supposed to be replaced every 30K. How many miles do you have on your G?
1 - 2 of 2 Posts
