1 - 10 of 10 Posts
I dont get it. It feels like its hung up around the bottom of the door handle area.
I took the window switch out and un did the screw behind it, as well as all the perimiter screws and the tabs that POP in to their respective holes.
How does this come off?
Does the handle itself rotate out like the S13 and B13's? It doesnt seem to want to turn so Im guessing no?
well you have to roll down your window, and then unhook to top portion that goes into the window channel. oh, pop door handle molding off so you can slide the thing out....
well you have to pull the door handle (the one to opend the door) molding off, otherwise the door will get hung up on this, the door handle will still be attached. what you do then is pull the panel from the door (usind the handle you use to close it) then, once you see everything is unhooked, pull up from the top of the channel and it should come out....
there might be a pressure clip there that comes undone when you pull the door towards you.... then just pull up
p10 guru
honestly, once you do it once, its like tying your shoes. they are really simple.
1 - 10 of 10 Posts
