1 - 20 of 46 Posts
Parts Supplied: Fog light (RH), Fog light (LH), Finisher (RH), Finisher (LH), Switch, Relay, Bolt (2), Spring nut (2)
Tools Required: Flat blade screw driver, Phillips screw driver, 10 mm socket
Notes: The ignition switch must be in the off position. With the ignition off, disconnect the negative battery ground cable. Leave the cable disconnected throughout the complete fog light kit installation.
Installation
Remove the fascia opening finisher from the front bumper fascia by disengaging the (4) tabs on the backside of the finisher.
Insert the spring nut onto the bumper fascia flange, aligning the attachment holes.
Caution: Ensure that the threaded side of the spring nut is on the rear of the flange.
Locate the gray 2-pin connector that is taped to the vehicle harness near the fog light opening. Remove the connector from the tape and plug it into the fog light.
To install the fog light, insert the (2) tabs on the outer side of the fog light into the slots in the bumper fascia. Secure the fog light with the bolt. DO NOT OVERTIGHTEN THE BOLT.
Remove the (5) screws attaching the steering column finishers. Remove the upper finisher only.
Remove the factory turn signal/light switch. (2) screws.
Save the screws for later reinstallation. Unplug the vehicle harness connectors from the switch. Discard the switch.
Locate the small white 3-pin connector taped to the vehicle harness above the switch attachment collar. Remove the connector from the tape and plug it into the new fog light/turn signal switch from the kit. Plus the vehicle harness connectors into the new fog light/turn signal switch. Install the new switch using the (2) screws previously removed. Replace upper finisher (5) screws.
In the engine compartment, remove the relay box cover located near the passenger side strut tower. Install the relay in the blue relay socket, 1st from the front on the inside row as indicated on the relay box cover. Replace the cover.
Notes: The fuse for the fog lights is pre-installed at the factory.
Check the fuse box next to the battery to confirm the fuse has been installed.
When aiming is completed, install the fog light finisher by inserting the lower tab into the groove on the fog light housing. Snap the upper tab on the finisher into the slot on the fog light housing.
Fog Light Functional Check
  • The fog lights operate only in conjunction with the low beam headlights.
  • Turn on the low beam headlights.
  • With the low beams on, the fog lights should turn on and off with the fog light switch.
  • With the fog lights turned on, switch the low beams to high beams. The fog lights should turn off when the high beams are turned on.
  • With the fog lights turned on, switch the low beams to park lights only. The fog lights should turn off when the low beams are turned off to park lights only.
Discussion Starter · #2 ·
Fog Light Aiming
Properly aimed fog lights require that the high intensity zones of the light beam are positioned 4” below the horizontal center line of the fog lights at a distance of 25 feet.
Park the vehicle on level ground perpendicular to a wall 25 feet away.
Measure the vertical dimension (a) from the ground up to the center of the fog light. Subtract 4” from this vertical dimension. Mark this shorter dimension (b) on the wall directly in front of the vehicle; dimension (b) = vertical dimension (a) - 4”.
The Phillips head fog light adjustment screw is near the lower inside corner of the fog light.
Turn on the fog lights. Adjust the fog lights so that the top edge of the high intensity zone aligns with the dimension (b) mark on the wall.
All of the wiring is already there for g20s that dont already have fog lights. You might have to reach around for the wires because it is taped so it won't hang. But the wires are there. Cut the tape and you will see the connection. There is a seperate switch that has to be installed with a control for the for lights. If you buy from everything20.com the kit will have the lights and the switch.
1 - 20 of 46 Posts
