G20 1996 Stock OEM Fog LIght Installation
I just installed some stock OEM Fog lights My G20 is a 1996 , the other day, bought some at a wrecking yard, got em, went home, made the cut outs, found the wiring jack, that connects to the fog lights, inside the inner wheel well Left side, and the Right side, had to partially open, or remove inner front wheel well plastic cover, from under, for some space, Jack up the car in the front and remove front wheels. Didn't have to remove entirely the inner wheel well plastics. Connect the wiring, bolt on the Fog Light Bracket, insert the fog lights, from the front area, didn't have to remove the front bumper plastic cover, then Install the switch, at the front plastic trim bezel, for your climate control, and radio area, plug the switch, to the receiving male harness, then, insert the Fog Light Relay, in the inside Hood engine compartment area, check for fuse in Cab area, fuse was all ready there, Turned on lights, then hit the switch and it works.
