Very nice!
Yes, you will need a throttle body adapter that adapts the 32 bit IACV.could this be done running the 32 bit ecu?
I bypassed the IACV by running a manual valve on roller rocker manifold (was already OBD1 ECU with NEMU).So you used an adapter to tune with the roller rocker plenum first?
I had seen also a roller rocker make 125whp with intake header and exhaust on it's stock ecu and clutch started to slip some.
I used the EGR turbe as a giant hole to the intake manifold for the homebrew IACV. I had to cut most of the EGR pipe away to fit it, worked out fairly decently actually.Egr mounted air regular? Lol
Hey what ever works. Now only reason I asked is because you say same tunes
And the cowper pics look like you use either nismo 555 injectors are suby yellows
Not trying to say anything IM just unclear some.
I having set up a modded USDM plenum can only say I like the way the roller rocker responds to the top feed 550cc injectors. But this car has yet to see boost are a dyno.
IM just wondering if I should push to make a new plenum for him welded to the top feed bottom
You might be able to actually if you can make an adapter to use stock RR IACV. The two emissions pieces on RR are EGR and vapor canister. Vapor canister is just a solenoid that you hook up to any 1/4" nipple on intake manifold. EGR would get tricker to properly route (might need to weld).Can all oem smog equipment be retained for us that live in CA?
EGR should be really close. You would want to use the EGR tube from the same vehicle you removed the intake manifold from. Maybe some heat to the EGR tube itself, you can get away with some slight bends to get it to line up.You might be able to actually if you can make an adapter to use stock RR IACV. The two emissions pieces on RR are EGR and vapor canister. Vapor canister is just a solenoid that you hook up to any 1/4" nipple on intake manifold. EGR would get tricker to properly route (might need to weld).
i made 123 hp with I/h/e on a auto RR. All of my dyno runs have been like 118-123 hp. I would like to do this swap just to see what it can really do..i mean even 10 hp would make it worth it on a auto G20 with no where else to go but boost or nos or s3r cams for more power.So you used an adapter to tune with the roller rocker plenum first?
Good luck, you will need to come up with a custom EGR pipe, then to mount the RR throttle body you will need an adapter plate (do note that by using adapter plate you are technically increasing the volume of the manifold).![]()
gonna make this happen going with the full emissions intact on 32bit ecu. then we can test this 10HP untuned theory on RR ecu.
I have a set of 259's that I wont be needing anymore, let me know if your interested $35 shipped.thanks for the idea.that manifold looks so boss on the RR motor. I do plan on doing a tad bit of porting on it and hand polishing the top plentum. The runners are gonna be painted blue. I can totally do this. I didn't take the injectors from pull a part because 1 of them was broke. but i do have the injector clips. I don't think finding injectors will be that hard though. I will admit that pulling it from the 95 G20 was a pain in the ass towards the last few bolts. Lol but i learned some stuff. Hopefully taking off the RR manifold wont be as hard. Lol
Nope computer wont care much, unless 32 bit's are very dependent on volumetric efficiency. Since your planning on porting and polishing the manifold too, it wont matter that much since your changing a few more variables anyway.you think the computer will notice the manifold volume change with the TB spacer? Lol
I may do that if i can't come up on some local. Yeah i really don't even have to have the car code free because i'm registered in a county that doesn't have emissions but this is more just to see if it can be done and what the results will be. If i have to delete egr for a second than i guess i will have a code for it until i come up with custom pipe. Lol I have dynoed my car 2 times already so i know with the right tweeks i could put down 135.I have a set of 259's that I wont be needing anymore, let me know if your interested $35 shipped.
