i've searched but i can not find the procedure to pull the ses code. on honda's there is a plug you can jump with a paperclip or wire and get the code. is there a similar way to do this on nissans/infinitis, or do i have to buy a scanner tool? tia.
i dont have permission to access that page :(
I presume this is for the '02 P11....
There is a screw on the side of the ECU on earlier G20s but the later ones don't have it so go to Autozone and have them pull the codes with a scanner.
On the Euro P10s and P11s you can do the paperclip trick but a couple have tried on Infinitis and it hasn't worked.
