1 - 20 of 120 Posts
"says here on your chart"
Got this from Sr20 Forums (see link)
http://sr20forum.com/showthread.php?t=175334&highlight=p11+speed
Parts list
Spec V tranny 02-06
Spec V axles
Spec V spindles if you have a B13 or B14, Not needed for B15, P10 or P11
SpeC V shifter and shifter cable
Spec V master cylinder, not need for P11
Spec V Hydralic line, not need for P11
Spec V clutch pedal, not needed for P11
Spec V tranny mount driverside, need to make proper mount on B13, B14 and P10
Spec V rear tranny mount, need to make proper mount on B13, B14 and P10
Spec V rear Tranny mount bracket, need to make proper mount bracket on B13, B14 and P10
Make sure the guys at the junk yard dont break anything as the remove the parts
Axle bracket for P12, order from Greg V
Bell housing for P12 20V tranny, order from Greg V
JWT Flywheel for 6 speed tranny on SR20DE also known as S15 flywheel
300zx TT 250mm clutch for turbo cars and 240mm clutch for NA cars
If you are NA use the 02-03 Spec V tranny.
If you have Turbo use the 04-06 Spec V tranny.
If you have a P11 car this is a very easy install. I dont even need to give instructions
If you have a P10 it is also easy but you wll have to put the Spec V clutch pedal in and convert to hydralic. You will also have to make an engine mount for the tranny passenger side.
B13 and B14s are a little harder.
You will need to convert to hydralic and also convert the B15 spindals from 4x114 to 4x100. There are many ways to do this, One way is to punch out the bolts, weld the holes shut and have the new holes drilled for 4x100. You should also be able to punch out the bolts and just redrill new holes making the hub a 8 hole patern with 4x100 and 4x114.
I have never tried this part but you might be ableto press out the center from the B15 and press it into the B13-B14. I havenot tried this so I dont know but should work.
On the B13 and B14s you will also need to trim a pc off of the cradle. This trimming will nee to be about 1.5inch deep and 3 inch long. This can be done by lining up the stock trany in the car then measurig the diffrence of the 6 speed tranny. Once done take tanny out cut and weld back in suport pc.
Anyway all said and done an easy install.
What are the benifits of this install?
1. Way stronger transmission.
2. Much better fuel milage on the highway.
3. Much better clutch selections 240mm and 250mm (215 for or cars)
4. Less chance of thrust bearing failure because of less clamping force by clutch
Spec-v 02-03_____MPH______RPM DROP AFTER SHIFT.
1 : 3.417:1______36.3 _____1-2 4551
2 : 1.944:1______63.7______2-3 5176
3 : 1.258:1______98.6______3-4 6022
4 : 0.947:1______130.9_____4-5 6530
5 : 0.773:1______160.4_____5-6 6520
6 : 0.630:1______196.8
Final drive : 4.429:1
2439rpm @ 60mph
spec v 04-06
1st: 3.153_______42.1_______1-2 4932
2nd: 1.944_______68.3_______2-3 5728
3rd: 1.392 _______95.4_______3-4 6063
4th: 1.055_______125.9______4-5 6134
5th: 0.809 _______164.2______5-6 6655
6th: 0.673_______197.4
Reverse: 3.002
Final drive 4.133
2431rpm @ 60mph
05 Maxima HLSD ( Great NA Street Box On Street Tires )
1st 3.153 = 13.031
2nd 1.944 = 8.034
3rd 1.392 = 5.753
4th 1.055 = 4.360
5th 0.809 = 3.343
6th 0.630 = 2.604
Reverse 3.002
Final Gear 4.133
Toyota Celica GTS/ Matrix XRS (This Is A Great NA Box For Slicks )
1 : 3.166:1 = 14.333
2 : 2.050:1 = 9.284
3 : 1.481:1 = 6.707
4 : 1.166:1 = 5.281
5 : 0.916:1 = 4.148
6 : 0.725:1 = 3.382
Final drive : 4.529:1
Tibiron gear ratios ( Great Street NA Gear Box )
1. 3.153 = 13.961
2. 1.944 = 8.608
3. 1.333 = 5.902
4. 1.055 = 4.671
5. 0.857 = 3.795
6. 0.704 = 3.117
Reverse 3.002
Final gear ratio 4.428
Questioning Answers
damn......looks like im starting to get happy about rebuilding my auto & not swaping the 5sp.....now i can do this & save more money to get a vet.....damn i dream so big!
G MERA
I believe Miko said it was from 700-900 for all the parts. So if you can do it yourself then its not a bad cost.
I was happy and sad in the same moment when I read the write up. My friend recently smashed his 06 spec V, I could have purchased all the pieces needed, but now the car is crushed.......
I am working on this with Andreas. Its not going to be that much. For you P11 people it will be even easier, probobly the easiest of all. You can easily do this for under $1500 for everything, trans, bellhousing, flywheel, clutch, brackets, mounts, cables, shifter and so on. There are so many of these transmissions available that wrecking yards are selling them for as low as $300. i paid $350 for my 04 mint cond, super clean with a 1 year warranty. they had 9 more in stock at that price. I am just waiting for my bellhousing from japan...
Administrator
And when you get it in and together.. I might take a flight up just to check it out!! :naughty:
Administrator
nut180sx said:
does anybody have or have found pics of this swap????
As I understand it some of the parts are still in transit from Japan . But, the tranny, clutch and flywheel have all been sourced, purchased and delivered.
Give it a little bit of time. =)
Not yet, I am waiting for a few parts to come in from japan before i can actually start, that and I cant find a shifter or cables.
Administrator
enohand said:
ok i asked this over @ sr20forum....but um....what kind of bellhousing???? is it a custom one is it off a nother nissina what!??
I believe it's from a 20V VE motor, in a P11 in europe/Japan.
Administrator
markbuts3 said:
The P12 (W)20V was only sold in Japan :(
Yeah that one!! Posted by Mr. Google!! Err..um.. Mark.. :cheese:
1 - 20 of 120 Posts
