1 - 12 of 12 Posts
How the hell does everyone remove the headlight unit.....I need to change the corners to Cryss's stealths, I got the 2 top bolts off and now I gotta get the others off can someone help me with this..........any ideas?
its been a while, and im at work... but theres a 3rd bolt on the underside that needs to be loosened. i know its been covered, so searching will find your answer. sorry i cant help more right now.
on to the next one..
the third bolt is a bitch. i dont rememeber where it is, but its a nut that goes around a threaded bolt on the headlight (if that makes sense). i believe it is a 10. i didnt even put the nut back on when i replaced my headlights haha
*BANNED FROM G20.NET*
10mm socket, 3 inch extention for ratchet. should be down the middle on the back side;more towrds the inside
once you get those off, in order to the get it off you need to give it a good hard tug. if you feel as if youre going to break it, youre doing it right haha
Internet Mechanic
P11Gdub said:
be careful not to break the green clip. i broke mine. X(
break the green clip it doesnt matter
i'll try to find a print out i got from the dealership. it shows the location of each P11 headlight component.
1 - 12 of 12 Posts
