Can anyone verify if this turbo and manifold came off of a SR20VET?
R roblop04 · Registered Joined Oct 24, 2006 · 2,878 Posts Discussion Starter · #1 · Sep 5, 2014 Only show this user Can anyone verify if this turbo and manifold came off of a SR20VET?
Snickers · Registered Joined Jan 3, 2004 · 11,110 Posts #2 · Sep 5, 2014 Only show this user Yes. Looks like VET. The manifold has the notches in it that should get welded up and the turbine housing looks correct
R roblop04 · Registered Joined Oct 24, 2006 · 2,878 Posts Discussion Starter · #3 · Sep 5, 2014 Only show this user ^^Thanks^^ Newb Question but would this turbo be good for about 350hp?
Snickers · Registered Joined Jan 3, 2004 · 11,110 Posts #4 · Sep 5, 2014 Only show this user Low 300's. Maybe 320whp @16-17psi on a VE
Y2KG20 · Registered Joined Aug 27, 2012 · 1,380 Posts #5 · Sep 5, 2014 Only show this user Aren't the VET turbos basically a GT2860 garrett?
R roblop04 · Registered Joined Oct 24, 2006 · 2,878 Posts Discussion Starter · #6 · Oct 3, 2014 Only show this user Y2KG20 said: Aren't the VET turbos basically a GT2860 garrett? Click to expand... found out its a Ball Bearing GT28R.
G ghostraider44 · Registered Joined Jul 19, 2008 · 38 Posts #7 · Feb 10, 2015 Only show this user stock vet has gt2560 turbo with no BB. I have nissan xtrail gt 2003.
S shaztgo · Registered Joined 21 d ago · 1 Posts #8 · 21 d ago Only show this user What aftermarket sr20vet Turbo manifolds are available for the x trail gt, are the sr20det ones compatible?
