21 - 34 of 34 Posts
· Registered
Just cut the blue and white wire coming out of the head unit (aftermarket standard, don't know about OEM) which signals the antenna. I then put it in line with a fog switch on the dash so I can toggle it as needed.
_SHig
· Registered
I'm reviving this thread from the dead.
So I disconnected my antenna after Installed my Blaupunkt headunit a couple months ago. The antenna goes up when the headunit is on (cd or radio). Sometimes I dont get good reception in some areas.
Can I just cut one of the wires from the harness that turns on the antenna? that wont make it go up?
· Registered
Put an extra flasher button in your dash and wire the blue wire from your head unit through it so you can toggle the antenna up and down when you want to. I've got my antenna switched using a spare fog button.
_SHig
· Registered
push it down just be careful to not bend it...
Gratsi for le reply!
I already tried that but i think it's jammed because no matter how much i push down it wont go down....i think im just gona pull it out and bondo the antenna area and make it look like it never existed lol.
· uruG 02G
My Alpine H/U is nice, if it is on anything other then standard radio, the ant doesn't go up, and i can switch between say "iPod and Sirius" without having to go past terrestrial radio, so my antenna never goes up. It's a good fix too (FYI)
21 - 34 of 34 Posts
