Ok, so I rewired back to stock after the one bulb was out. Now neither are working. Fuses and relays are all fine so I don't know what I could have done? I'm positive I didn't mess up the wiring.Check your grounds, for shorts, fuses. Rewire back to stock, troubleshoot from there if all else fails.
Leave it to me to screw up on one of the most simplest mods you can do. :shifty:You screwed the pooch somewhere.
Check your relay switch. Idk how it happened but mine was fried when I checked.
If they were working fine before then its something that you've done thats messed up. Pics help.
