1 - 20 of 98 Posts
Search words: P11 remote, key fob, remote key fob, setting remote, setting key fob, resetting key fob, resetting remote.
I decided to buy an extra key fob for my P11 because I only had one. Anyway, found it for $20 or so including shipping on ebay. To get this new key fob to work here is what you have to do. These are the instructions that came with it and they do work.
----Instructions----
Replacing Remote Controller or Multi-Remote Control Unit (LCU05)
Enter the identitiy (ID) manually when:
- Remote controller or multi-remote control unit LCU05 is replaced.
- An additional remote controller is activated.
ID Code Entry Procedure
Setting Mode - do this while in the car
1) Close and lock all doors.
2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time the origional ID codes are eliminated.
ID Code entry
3) Turn ignition key to *ON* position - one click past ACC but before crank.
4) Push the lock button on the new remote controller once. (The hazard warning lamp will then flash twice.) At this time, the new ID code is entered.
Additional ID code entry (additional key fobs)
5) Unlock the driver's door, then lock again with the door lock knob. (switch on arm rest)
6) Push lock button on the additional new remote controller once.
7) This ID code entry enable state and setting mode remain until the driver's door is opened.
Notes:
- If you need to activate more than two additional new remote controllers, repeat the procedure Additional ID code entry (additional key fobs) for each new remote controller.
- If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
- Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
- Any ID codes entered after termination fo the setting mode will not be accepted.
- Additionally remote control signals will be inhibited when an ID code has not been entered during the setting mode.
----End Instructions----
Hope this helps anyone that needs this information. In addition put new batteries in your key fob, this is just for good measure.
Hey since you car is a 99 too , can you buy any p11 remote and it will work ? Thanks
I had one from a 2000+ modle and it would kinda work.....but the 99 ones (without the trunk button) that I got on ebay worked flawlessly.
Awesome Pat, it worked for me!! 2002 G20 Sport
My car only came with one key and no remotes, so I programmed my 3 old remotes, it didnt work the first time and at the dealer they told me they couldnt do it that I have to get new ones. So I took out from my pocket Pat's directions as they told me it was bullshit and behold I did it, the service guy then asked me how I did it, and I told him I dont know!!! Its magic!! Later dude! Have a nice day bro!:smoke:
These worked for me on my 99 two a while ago ......
Re: GooD Sh*t To Know!!!
THE20 said:
Nice Work I was about to go pay 45 Bux! Now i have money to take out my girl !!! lol
If you can take her out for only $45 , she is a keeper !!!
;) ... Where do live again ? $45 bucks in Miami is 2 drinks on South Beach ....
Re: Re: Re: GooD Sh*t To Know!!!
Yahnozha said:
w3rd....thats like a months worth of dates at Tako Bell.... :lol:
LOL a lot of Cheesy Gordita Crunche's!!=)
Re: Re: Re: Re: GooD Sh*t To Know!!!
mmm cheesy godita crunch..... :cheeky:
oh i was wondering, any way to get keyless trunk entry on a 99? thats one thing i miss about my '00
drunken master
its the same prosedure for all newer nissans dont now about the older one's havent worked the long enough
enohand said:
now would this work on a 00 g20??? i got 2 keys but no keyless entry remote??
YES
My minivan (Mercury Villager, same as Nissan Quest) has similar remotes. I tried to program the van's to accept the G20's remote but it didn't work.
The procedure to program remotes is the same for both vehicles. The van's system doesn't recognize the G20's remote.
I hate to carry two remotes, make the keychain too bulky.
Carl
99 G20t
enohand said:
would any other remote from any other nissan/infiniti work?? beside for a g20???
Infiniti I30/QX4 and Nissan Maxima/Pathfinder I think as long as the FCC ID is the same.
1 - 20 of 98 Posts
