This is my first gnet HowTo UKDM Duals
Tools you'll need.
10mm socket
rachet of choice
hammer
vice grips
The duals
Ok, this is gonna easy if you already have removed your headlights before.
I have, so i already broke the green tab on the back, and didnt put the
hard to reach 10mm bolts. so holding on my headlights are 2 allen key washer kit (you should have 10mm bolts)
Lets start by taking off the bumper, you will need to do this if you havent taking out your
headlights before, i didnt have to take it off
Then remove the headlight
she has a black eye
Now we test fit the dual, there are some parts that need to be pulled and pushed in for the duals to
sit properly, this is when i used the hammer and the vice grips
this need to be pushed back towards the a/c condensor
here need to be hammered/pushed down, also where the black thing is on the upper right need to hammered in
this need to be pulled up
you're gonna have to hit it, test fit pull/push a few time, before perftect fitment
then bolt em down and repeat for the other side
when done should look like this
congrats you just installed UKDM Duals on your P11
I AM NOT RESPONSABLE IF YOU BRAKE OR MESS ANYHING UP ON YOUR CAR, IF YOU DO THEN JUST STOP AND SELL YOUR CAR AND BUY A HONDA
Tools you'll need.
10mm socket
rachet of choice
hammer
vice grips
The duals
she has a black eye
