I broke one of the long bolts going into the plenum after pulling it for about the 4th time. It is the one in the middle FYI.
I can drill it out some other day. For troubleshooting purposes I would like to know if this is guaranteed to now create a vacuum leak.
I just can't be annoyed anymore and need a break from this crap. I pulled it to replace the ARV with a brand new one because I am sick of going down there and want to rule the ARV out.
Thanks
I would say that no , you will probably not get a vacuum leak , one missing bolt won't create a vacuum leak so long as the other bolts are ok & torqued to specs.
The gasket should be ok ....damn that sucks i hate to hear about broken bolts because i've been there before too.........good luck
Good.....thanks
