1 - 2 of 2 Posts
I finally got it. It needs some work like the transmission which has the 5th gear pop-out. Any way I just got it home and am thinking about whether or not to put in an se-r tranny. It is the same price for the tranny itself but I think labor will be more. How much more work is necessary to install the se-r tranny instead of the p10 tranny? I will put some pics up tomorrow.
Also I am getting the tranny for 450$ plus 55$ shiping. Is that a good price if not do you know where I could get it around the Miami area for less. Thanx
Do a search on this, there is more work/fabrication required if you want to swap in the SE-R transmission. If you can find a replacement G20 tranny I'd probably have to recommend that cause it'll be cheaper and an easier swap to do. But if you search I know the modifications that are necessary for an SE-R tranny to work are listed on the forum. Hope this helps.
1 - 2 of 2 Posts
