i notice when i press my brakes my acc lights dimm, and when idleing if i press them some times it sputers.. if anyone has any ideas i am open..
add
You probably have some sort of short with your brake lights. You may want to trace your brake light wires to see if the circut is being grounded somewhere along the way. Otherwise it sounds like a battery/alternator issue. If it only really happens when you press the brake pedals though, its almost certainly a bad circut.
i had a similar problem with my car. lights would dim if i depress the brake. try your power windows too, if that dims the lights it could be your alternator beginning to go out. take a voltage reading on your battery when your car is on, it should be in the neighborhood of 13.8V - 14.4V, if it's any lower than that then your alternator is on the fritz.
