Im gonna be pretty quick and to the point with this.
I have a 1991 G20, Automatic-transmission
-I think my engine is idling too high, how can i find out/fix it?
-When I accelerate, as i go from first to second the engine kinda revs higher than it needs to and then drops back down, giving the car a kinda jolt when i drive. It happens between the other gears too, but its not as prominent, without the kick. Any ideas what this might be?
-Just yesterday i developed a knocking kinda sound from underneath the car, and im kind of afraid to drive cause it sounds like its coming from the transmission, though im not sure if it is or not. Any ideas?
I had the same problem with the kicking out of first hard, also when I put it into gear the engine would jolt. I opened the hood and on the driver side about half way up the engine againt the frame there is a plug and it was unpluged so I pluged it back in and it was fine, no kicking at all, but that could not be the problem but you might want to check it out.
