Questioning Answers
if ur shaky & u know it look here...(HUGE p11 suspension busing replacement guide!!!!
ok well maybe it aint, buut i would like to star compiling it...
i just went threw almost all the suuspension threads searching for info on bushing for the p11, didnt really find a whole lotta anything on 1 specific post so i decided as a community we should all get together & complie a little list (also my suspension is shot & i wanna reaplce anything i can when i takcel that proect)
well i know that octat sells a superepro bushing set that doe the, LCA, camber rods (or whatevere thie called), & the ball joint..??(im not sure/ i think he said u go ooutu & buy an oem one)
so i wanna know were to get these buushings in uurethene
tierod
rear beam.....acctually i dont think i read anything about anuy busings in the rear for the p11, so everythuiung & anything in the rear thats a bushing in the P11, please if u knw anything list it........
i wanna try to keep this thread clutter free so, no BSing
subscribed. polyurethane bushings are the last suspension parts i need to do before moving onto the brakes. well that and the 3 point brace.
On the front for the P11, superpro make the top link camber adjustable bushes/sleeves and for the LCA you can get the front bush.
In the rear you can get the trailing arm bushes.... SPF1942K
Sponser how-to
You can get the ES bushings for the front sway bar drop links and for the sway bar mounts.
Let me add to this.
Front sway bar bushings - Energy Suspension p/n 9.5124. They are the 20mm size. http://www.energysuspension.com/pages/swaybbct.html You need to go to the bottom half of the page. For some reason, you need to use the 'non-greaseable type'
Also, you can replace the Stabilizer End link bushings - ES p/n 9.8106 - http://www.energysuspension.com/pages/endl.html The kit comes with 8 bushings, but you only need 4! So share with a friend. Oh! I found that the washers included with this kit didn't fit - the hole ID was just a little too small - So I just reused the stock ones. Which is not an issue.
Thanks for the ES links, I wasn't sure on the P11 size. You need to use the non greasable ones as the hole spacing is correct on that one.
Joel, you should know better :p. When it's warmer and lighter in the evenings :)
Let me add to this.
The links dont work anymore. How do i purchase these? thanks
