1 - 7 of 7 Posts
magnificent pooper
Individual Throttle Bodies (ITB's). So i just heard about them, and I've grasped the basic concept. Anyone know more about them, and would like to give their two cents, maybe offer pros and cons (from your perspective)? Maybe a true mechanical outlook, even short term/long term advantages and disadvantages?
1. no real HP increase
2. majorly $$$ project
3. PITA getting to work because your intake has a maf
itbs are more a response thing but if u really want to do it i hope you have some fab skills
as far as management you will need to get rid of your maf unless you use a plenum of some sort so that means new ecu of some sort, or hacked version of yours if your a computer guru :)
magnificent pooper
Oh no, I'm not planning on using it, I just want to know more about it. I think a custom turbo project would be a little more cost worthy before attempting this :p.
I have them in my Celica with open velocity stacks and love them. My throttle response is amazing and the open velocity stacks sound mean. :)
The motor came stock with the ITBs though, so I can't compare to not having ITBs on the same motor.
Prince of Joy
ITB's are definitely superior to a single TB on the end of a plenum -- mainly for throttle response.
Take a look at the GTI-R SR motor. It's got ITB's.
Doesnt matter if you have a MAF system either... it's a long way away from the ITB's. The total flow is still measured as usual.
All the ITB's do is equalize intake pressure at each cylinder.
- Greg -
1 - 7 of 7 Posts
