whats the web address for the company that sells infiniti accessories i'm looking for the sill plates?
Cheers guys,you are all so helpful.Seneb the site you posted was the one i was looking for.Them clear side markers are really cheap if they are for a pair and i pressume they will fit the p11 primera.Do they fit in the same way as the uk ones, push one side and lift the other out to remove.
yeah, that sounds about right for the install. they might have a bit of a different connection, so you would have to make some small cuts on the back to make your connection work. check out yahnozha's info on this: http://www.customsteel.com/2001/MyG/ then click on how to and then clear side...
