1 - 20 of 49 Posts
Parts for sale 1994-1996 P10 Infinity G20 2.0L:
- ABS module, computer-30
- Front low control arms ball joint Left side-30
- Throttle sensor -30
- right front inside handle-10
- INTERIOR PARTS radio/heater bezel(brown color)-50
- TRANSMISSION COMPUTER OEM #31036-0J200-40
- GLOVE BOX (brown color) - 40
- SMP/STANDARD ETS46 EGR Valve- 30
- TRANSMISSION COMPUTER OEM #31036-0J260-40
- RIGHT REAR DOOR GLASS- 25
- Wiring Rear Trank-30
- LEFT REAR DOOR VENT GLASS- 25
- FRONT HOOD GATE LID HINGES SHOCK- 25
- REAR TRUNK GATE LID HINGES SHOCK- 25
- INSIDE REAR VIEW MIRROR- 20
- Headlamp/Turn Signal Switch- 25
- STEERING WHEEL(brown color)- 30
- LEFT REAR DRIVER SIDE Door lock Actua- 20
- ANTI LOCK BRAKE COMPUTER ABS -30
- Rear RIGHT Passenger Door lock Actuat...- 20
- Right Front Passenger Door lock Actua...- 20
- FRONT PASSENGER Door Handle Outsid -20
- THIRD 3RD BRAKE LIGHT W/ HOUSING- 20
- CONT ASSY KEYLESS - #28594 78J10-20
- Cont Assy ASCD - #18930 62J15 -
- LEFT and right INSIDE DOOR HANDLES- 10
- Door Lock Timer - # A4616 - 15
- HEAT AC TEMP CONTROL -25
- REAR PASSENGER Door Handle Outside -10
- MIRROR DIMMER CRUISE VENT PANEL ASSY-15
- CRANKSHAFT SENSOR -20
- DOME LIGHT LAMP ROOF SWITCH TRIM -10
- CENTER CAP -#4034278J00 -10
- LICENSE PLATE TRUNK LID LIGHT -10
- Door Handle Front Passenger side -10
- a/c radiator -35
- 1 rotor,rear -10
- inside mirror -20
- sunroof motor -20
- ignition cover -35
- A/T control unit -25
- A/T mode switch -25
- A/T revolution sensor -30
Kent,98031 WA
do you have the two front window switches that go in the door. if so how much shipped to 06851
1 - 20 of 49 Posts
