Hi,
Does anybody know how big the diameter of the inlet of the Intakemanifold of an p11 gt is?
After the trottlebody.
After the throttle body ??
I can tell you that to fit a 64mm bore TB, you have to machine the plenum, so I assume it's 60mm like the std throttle body.
Ok the reason y I asked was because I wanted to put on a bigger TB.
So if it is 60 I'll have to do some work in it.
Thanks Dan
