41 - 55 of 55 Posts
· LAST5DOA
Discussion Starter · #41 ·
The jist of it is that im connecting the "jumper harness" to the High beam wire and the HID ballast low beam wire on the relay harness correct?
Yes, you are tapping the high beam jumper wire into the lowbeam wire with the diode inline (make sure the line on the diode is like in the pic).
When you power the high beams on the OEM relay shuts off the low beam signal, but the jumper maintains that signal by tapping back into the lows...The diode provents that from always being the case.
· Registered
So since my Hi-beam and Lo-beam wires are both on my h4 connector (hi-beam spliced for duals HID) Then theoretically I could just cut a small section of the plastic both wires and candy cane + solder them without any extra jumper wire? Did that make sense?
Like this! Then Electrical tape the crap outta solder points.
41 - 55 of 55 Posts
