Be part of the elite... only 1 available. 250+ shipping
email me at [email protected] for faster response
The motor does not come come with a plastic cover since it goes below the rear shelf. There is a hole in the rear shelf which the shaft of the wiper motor assy passes through.You verify the wiper motor works and the do you have the plastic cover for the interior of the motor housing as I am assuming it sits above the rear shelf?
Thanks for the clarification! Another question is where was the OEM switch located for it in the P11. Was it on the windshield wiper stock with front or a separate control on dash? Also was is multi speed?The motor does not come come with a plastic cover since it goes below the rear shelf. There is a hole in the rear shelf which the shaft of the wiper motor assy passes through.
On my p11 and all the other jdm p11's that I've seen the rear wiper controls is on the wiper stalk, not a seperate switch on the dash. Also I've never seen one that's multi-speed. It basically came in two flavours:Thanks for the clarification! Another question is where was the OEM switch located for it in the P11. Was it on the windshield wiper stock with front or a separate control on dash? Also was is multi speed?
