1 - 12 of 12 Posts
im wondering if you guys think $300 is a good price for 3 w3 jl audio subs with a custom box. this equipment will be used and i want to know the specs of these subs and your opinions on them. also is it advisable to buy them used because i dont know if they were abused by the previous owner. i just want some information on these subs and if you guys think i should get them considering their low price. thanx
G20 Junkee
those subs fuckin ripp!
If they are 12's thats a ok deal, 10's its ok
Im not sure about the currency conversion
to get the specs, www.jlaudio.com is a good place to start. if u dont no how the subs were used, u got a 50/50 chance;)
I'm assuming they are 10's. New 12's run about $180-200 a pop. W3's are great subs. I have 2 12's and they hit harder than Barry Bonds. If they weren't abused, I'd jump on it.
I got 1 W3 and the thing is tight! i got it for about 170 because it was an open boxed item, but new ones are usually around $200. if you can listen to them before you pay for them, then that should make up your mind.
whats so special about those v2 subs?
hey guys im thinking of just not buying the 3 10w3 subs for $300 and instead just buying a single brand new 12w3. my only question now are the ohms. i have the option of buying 2, 4, 6, or 8 ohm subs...which ones should i get. since im not too audio inclined id like to know what ohms are also. what should i do? a new 12w3 or 3 used 10w3's? im torn between the two!
note: oh yea the guy selling me the used [possibly abused] 10w3 subs brought the price down from 300 to 250. these are for 3 subs.
ohms is the amount of resistence. the greater the number, the more resistence it has. for examle, a amp might put out 100 watts at 8ohms, 200 at 4, 400 at 2, 800 at 1. so consquently u get a more powerful amp if u run at lower ohms. if u run at low ohms, u have to make sure ur amp is stable at that number of ohms. amps will say somethen like 2 ohm stable. that means u can run the amp at 2 ohms w/ no worry of burnen it out.
i would get the 4 ohm. it has the most options. u can run it at 4 ohms our 2 ohms if it is dvc(dual voice coil) which i think it is.
Discussion Starter #11
wow, thanx that helped! i was thinking the same thing since alot of people on this board have 4 ohm subs...cant go wrong when everyones doin it! lol
i'm running 2 jl 12w3d2 - the ones with the dual 2 ohm voice coils and an mtx 2300x all in 2 ohm, sounds pretty good, i just wish my damn seats would fold down...:angry:
1 - 12 of 12 Posts
