When i use my remote control to try to lock the doors it will not lock them, but the lock button does work on the remote as it will set off the alarm (holding it in) and also make the alarm activate if you lock the doors from inside the car before you exit.
What would part would cause the issue of the car not being able to lock the doors from the remote. Other than that everything functions perfectly.
p10 guru
sometimes my lock button inside the car sticks forward (in the unlock position) and wont allow the keyless to lock the car. probably not the problem tho, as you cant lock the car from the inside either.
