jayntguru said:
My 93.5 non T came with it. Are you sure yours doesn't have it already?
Yes. Keyless came with the Leather Package, which was standard on touring models and optional on non-touring.
jbloggs_c said:
there is actually one problem with the system i got put in. if you lock the door without using the remote but unlock it with the remote, the alarm goes off when you open the door. i have no idea why this happens, but its not a big deal.
So you're saying if you lock the door with the key and unlock it with the remote, the alarm goes off? I think this is because of the stock security system, which goes off when you unlock the door from the inside. This is supposed to deter the car thief who busts open your window and unlocks the door from the inside. I have set it off myself several times myself, when I've been sitting in my car for a while with the doors locked and unlocked the door and opened it or just when the window was down and I reached in and unlocked it from the inside.
What you're describing is exactly what I want to avoid in installing keyless entry. It seems there are two wires to tap into, one from the key lock, one from the door lock, and the computer can tell which is active. So theoretically, if you tapped into the key lock's wiring for the keyless, the computer would think you were unlocking the car with the key.
I've also heard that the INFINITI keys have a microchip in them, but I'm not sure why, and whether this would present any problems with a keyless entry system.
Any thoughts???
