this is the last time im gonna ask about keyless entry then im gonna give up.
I have a 93.5 g20. It has stock keyless entry. The FCC an the other # on the back of the keyless entry match with the stock keyless entries from other threads. It has a new battery in it. When i push the buttons on it, they beep, but nothing happens on the car. I know which buttons do what, so im not pushing the wrong buttons or anything. here's where it gets confusing. The keyless entry didn't work when i bought it. When i was at work one day i was fuckin around with my keys an i hit the buttons an looked outside, i saw the parking lights on my car blink(it had never worked till then). So i went outside for a minute an tried all the buttons out, they all worked, i went back into work. When i got out that night an went to my car, the keyless entry didn't work again and hasn't since that one time.
WTF is going on!
thanks for taking your time with this confusing shit
1
Discussion Starter · #2 ·
BTW the numbers on the back on my keyless entry are:
FCC ID: A269ZJA073
DOC/MDC: 700 K922
sounds like an intermittent problem with the transmitter/reciever and you'll probably need to get a specialist to look at it. You might need a new fob coded to your car though.
well why wouldnt you just take it back to the shop to get it looked at.? i just got an alram with keyless. works perfectly.
good luck.
good luck.
What shop? Nissan in Japan? He is referring to the oem factory keyless entry that came with his car new.
spita07, like xenobait said. It sounds as if your receiver (alarm remote unit) is malfuntioning, not the remote. I think you had mentioned before that you already reprogrammed your fob to work with your car. If you did, great! Then you know it's the alarm, not the key fob. If not, search the automotiveforums.com G20 forum for it. The procedure is over there somewhere.
Hope that give some direction.
Johnny Blaze said:
Do anyone know how much it would cost to get a new ketless entry control because when I bought my 96 G20 it didn't have the controler with it. Or does my car not even have that.
Ok. I went through this same situation with mine. Note the year of my car is the same as yours! If I am not mistaken ALL G20t's have keyless entry!
Save yourself some time and go to a dealer to ask them if you have the keyless remote module or not. It is located under the dash next to your steering column. It is attached to the factory car alarm if you have it. (I found this out too late, so..) I ended up buying two remote key fobs, spent a ton of time trying to reprogram the fobs to work with my car and nothing.
After 2 weeks of being pissed off, I went to the dealer to find that my car was equipped with the factory alarm, but was not equipped with the remote keyless module. I gave up, sold the two remotes and put a Viper alarm in. I now have keyless entry, trunk release and flashing lights.
ALSO NOTE: IT DOES NOT MATTER IF YOU HAVE LEATHER OR NOT.
The keyless remote module was an option that was installed at the dealership.
Discussion Starter · #9 ·
i'd like to say thanks to all of u for helping me out with this, but i guess it's off to the $tealership for me(once i get some money):(
1
