1 - 11 of 11 Posts
sup fred, im also looking for a key fob for my 00, when i got it it only came with 1 set of keys.. but since the keys are chiped and fobs are programmed to the car.. i think im going to have to suck it up and buy from the dealer.. might be your best bet.. unless someone else knows something i dont..
Bishous-G said:
schnap! you know how to program it? or do you need to take it to a dealer to set it up?
I programmed mine with these instructions.
http://www.g20.net/forum/showthread.php?t=7113&highlight=keyless+program
This one looks like the 99 one but you better check before you buy.
http://cgi.ebay.com/ebaymotors/2001-INFINITI-QX4-remote-fob-NISSAN-Pathfinder-01-00_W0QQitemZ8076249099QQihZ019QQcategoryZ33723QQrdZ1QQcmdZViewItem
Here's one that says Nissan on it. Check compatibility before you buy though.
http://cgi.ebay.com/ebaymotors/NISSAN-PATHFINDER-QX4-G20-99-00-KEYLESS-ENTRY-REMOTE_W0QQitemZ8077160453QQihZ019QQcategoryZ33723QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
^^^That one doesnt have the trunk release on it.
My current one does and the new one will as well. I just wanted an extra.
And thems the directions I'm gonna use too. :smile:
The 99's don't have trunk release, at least all of the ones i've ever seen. I dont think it was an option till 2000. I could be wrong though.
Yahnozha aka THEMAN said:
I had one from a 2000+ modle and it would kinda work.....but the 99 ones (without the trunk button) that I got on ebay worked flawlessly.
He has a 99
i used those same instructions on my GF's 2000 and it worked first time (getting into the input mode) but never seemed to take hold of the code, cause it wont work still. Now i can't even get it to get into that input mode (getting the hazards to blink after inserting and removing the key)
keep in mind that it SHOULD work but you might end up having to take to the dealer to get it programmed if you end up having as much trouble as i am having. btw anyone have any idea why i am having all this trouble? sorry if i am getting a bit off topic.
1 - 11 of 11 Posts
