In order is see the 5v at pin 27 you have to depin the wire from the harness at the ECU to isolate the ECU from the Engine then with the KOEO you will see 5.12v, then thereafter everything connected with no short in the wiring and a good 560Kohm knock sensor you will see 2.5v, this is do to ohms law as was discussed earlier.....the knock sensor generates a small voltage depending on knock or lack there of and on to the 2.5v and depending on the variations of these voltage are certain conditions a code 34 will be entered i.e. like the 3.32v with KOEO if definitely problem because the engine is not even running to cause knock so a code 34 is entered because that's an obvious no brainer.
