HEADS UP: THE SUB-HARNESS for a NISSAN KA24DE ENGINE I ORDERED FROM wiringspecialties.com IS ONLY 1 ft. LONG.
12 inches does not appear to be long enough to run from the KS to the harness plug-in next to the Idle Air Control Valve on the same side as the number 1 injector seen in the video.
* NOT QUITE LONG ENOUGH *
The reason I have revived this thread is that my high port p10's ECU is flashing the Knock Sensor code 34 and MAF sensor code 12. I have tested both of these circuits and the sensors themselves.
I am still getting both codes at the ECU.
(I verified the voltage running to the injectors, Key ON Engine OFF:
12.19V, 12.15V, 12.15V and 12.14V
And No continuity to ground from each injector connector.)
As for the KNOCK SENSOR:
With
ENGINE OFF, I removed the sensor and tested:
1.) the circuit from the ECU to battery ground ( NO continuity, infinite resistance )
2.) KS connector to battery ground ( NO continuity, infinite resistance )
3.) KS connector to terminal #27 on ECU connector ( YES continuity, 1.2 Ohms )
4.) The KS sensor is good, 566 or 569 Ohms.
With
ENGINE RUNNING,
1.) KS connector to battery ground, 3.32V
2.) ECU Terminal 27 to battery ground, 2.04V
I made sure the connector was attached snugly onto the KS sensor.
After reattaching the KS sensor, I checked the ECU codes. This time, it flashed the MAF sensor code AND the KS sensor code. I am not sure which one would cause the other, or if one would necessarily cause the other.
The KS sub-harness wire is exposed about 10 inches back from the KS sensor. It appears to be silver-metal wire. The heat shrink sheath is hard and cracked open. Maybe this is the shielded ground wire? Not sure if this would be the reason for the KS Code 34.
QUESTIONS:
Someone who really knows their stuff says they always upgrade to a 2-pin connector, one that has two separate wires, (one signal, one ground).
1. Where should the second wire be grounded to?
2. Assuming part of the existing harness is bad, Which chunk of harness is to be replaced, from the KS connector to where on the harness? Or is just a new sub-harness what is necessary?
3. Where can I buy a sub-harness that is long enough to reach from the KS to the connection on the engine harness?
As for the MAF SENSOR:
The engine barely runs with both the KS and MAF codes in the ECU, so it was hard to test for voltage with the engine WARM and RUNNING, but I managed to keep the pedal down so I could test the wires.
With the KEY ON, ENGINE OFF:
I tested for voltage and continuity on that circuit.
Power supply voltage ----> 10V on both MAF sensor connector, term. B to Terminal 17 on ECU (My other Digital Multi Meter read 11.8V.)
Ground Circuit Continuity ----> YES, MAF sensor connector, term. C to Terminal 17 on ECU
Input Signal Circuit Continuity ----> YES, MAF sensor connector, term. D to Terminal 16 on ECU
With ENGINE RUNNING:
VOLTAGE:
Terminal slot A --->
0.0V
Terminal
B --->
14.0V
Terminal
C --->
12.78V (Ground wire) After reading this post, I think I need to reground the MAF sensor. HowTo: - MAF reground (pics)
Terminal
D --->
12.11V
The FSM says (With ENGINE RUNNING) to probe Terminal
A on the MAF connector and that voltage to ground should be 1.3 - 1.7V.
There are 4 slots on the connector (
A-B-C-D) but
ONLY 3 wires that attach to it (
B-Orange,
C-White,
D-Orange).
QUESTION: Given there is no wire running to Terminal slot A on the MAF sensor connector, What exactly am I probing for when I probe Terminal A per the FSM's instructions? (Is there actually a wire that would deliver the 1.3 - 1.7V, Where would the 1.3 - 1.7V come from?)
