Okay, thanks to another thread i've used some tracer dye and a UV light and eliminated my crank seal leaking and the seal between my upper and lower oil pan. The only problem now is it looks like th oil is coming form above the oil pan. I've taken some dark pictures with the UV light so you guys can hopefully give me your opninon on what it is that is leaking and how to fix it. Thanks in advance.
These pictures are right below the passenger side looking up.
