is the ignition switch supposed to have a halo that lights up around it? And if so how do you change the bulb??
it was pretty simple just had to unscrew 6 screws to seperate the plastic column cover and the clear ring around the switch just slides off, the the bulb is right there, mine looked good so thought it was a wiring problem but tried it out in another car and it didn't work so swapped the bulb for a good one and poof it works, so even if the bulb looks fine replace it anyway. it is kind of awkward getting the cover back on.
