1 - 20 of 25 Posts
Can one of the Admins make this a sticky??
And maybe the write-up on bypassing the stock amps...
(Hint to the Admins)
Pinouts...
I have deciphered the pinouts on the rear amp's plug, if that would help. I think the front amp is attached to the rear of the radio. Does that sound correct? My 92 has a radio with the number "PK 429" on the cassette door.
More info on the 6.5" swap: Links w/ Pictures
Here are some links of installs people have done, either with the chevy brackets or by using some custom baffles.
Chevy brackets:
http://www.cardomain.com/member_pages/view_page.pl?page_id=237167
Note: See how this person first cut the bracket to fit to the G20 door panels, and then drilled new holes to fit the G20's stock holes.
Custom Baffles:
http://forum.soundillusions.net/showthread.php?threadid=24516
Note: This person decided to use MDF, fiberglass, and expanding foam to build some custom baffles. This route is good for people with speakers that don't fit the Chevy brackets.
THANKS! That will deffinately help....changin the front speakers soon! :alien: :cheeky: :cool: :asian:
New Tip:
We all know that the chevy brackets and in general, custom mdf baffles don't fit perfectly to the contours of the P10 door. Consequently, speakers don't get a good seal with the door...one tip:
Go buy a piece of weatherstripping material called peel n seal at your local hardware shop or whatever (home depot, walmart etc). It's pretty cheap, and generally sold by the sq. ft. It's for roofing and other weather/home related stuff - simply cut out a piece that fits to the back of the chevy brackets or to the custom baffle, and place it there. It should provide a good seal while also reducing the noises caused by vibration.
Good luck!
GOOD WORK, RYTE!!!
Now, how do I get the fnck!ng radio out of the console? My car has a Pioneer deck in it now (not installed by me), and I really want to replace it with my Alpine CDA-9815.
CowboyDren said:
GOOD WORK, RYTE!!!
The Pioneer if it was installed correctly requires a tool - basically two flat thin metal (not sure how far apart) pushed in on both sides of stereo at the same time - stereo should release from side brackets and slide forward - one caution - watch the single black wire that does not go into the harness - it bolts directly to the dash steel frame - and depending on the wire job - you may not have much clearance to 'disconnect' from the back of the stereo....
Hope this helps - most audio installers have that tool to pull the Pioneers out...
Thanks so much for putting this post on. Me and my best friend just put in the front speakers two days ago and I just bought some 6 1/2's to put in the back. We spent 3 damn hours trying to figure out how to get the stock speakers out. We never accomplished anything but really f-ing up my leather.
Can someone change the title and consolidate links to the top? I almost didn't look at this thread due to the title, but it contained info I needed (amp bypass, etc)
Has anyone tried the Kicker ks600 6.5" in front or rear? Crutchfield say's they don't fit the rear, but I'd like to put them in both locations. I wondered if there too deep for the front, or if anyones tried these why would not fit the back. I once had some Cerwin Vega's with 5.5# magnets would not fit a standard 6x9 hole. Wondered if it was something like that.
So I picked up a pair of these:
http://www.edesignaudio.com/product_info.php?cPath=1_21&products_id=33
If you can compare the specs in relation to size, you might be able to determine what it might be. I can tell you this fits like a glove/perfectly.
and the holes lined up perfectly as well. By the way, I think for the size and price, this is a very good buy. If you can seal it, it will sound much better, but I prefer the IB mode for space. I may pull these out and build a tube FG enclosure if we get another vehicle so I won't worry about space.
I couldn't find a good diagram for the pinouts on the P10, so I searched through the FSM and found the pages I needed.
Here you go folks.
Clickable for the large size.
1 - 20 of 25 Posts
