1 - 7 of 7 Posts
Hey all, 91 g20, standard.
Whenever i am going in reverse there is a loud sound.. i think it would be metal on metal coming from the rear portion of the vehicle. When i bought the car they said the rear brakes were at 30%... that was 2-3 months ago maybe.
I am thinking its the brake pads needing replacing because i am pretty sure my last g20 did the same thing.
Any ideas what it could be?
I just had the same problem or even worse. I had a squeal when backing up and some grinding when going forward. For me it was worn pads and mostly a locked caliper that was causing the problems.
With new pads, now I have some squeaks when backing out at first but I assume that is the brakes bedding in.
Rotors aren't that expensive to replace, but really it is a question of how they are. If they are smooth and you don't feel any problems when braking they may be fine even though the mechanic says otherwise. I would not resurface them as it only caused problems for me.
________
PORTE
1 - 7 of 7 Posts
