I am in the process of replacing the lower motor mounts on the 2001 G20. Carefully installed the new mounts on the cross member with the same orientation as the old ones. I noticed at the time that the center holes on the new mounts were not centered like the old ones. I have the cross member lightly bolted back in place and need to get the thru bolts back in place to finish the job. The front one is pretty close and I think I can use a drift or a big screw driver to line it up to get the bolt through. The rear one is off by more and I am not sure how to get it to line up better.
Any ideas to make this a little easier? Am doing something wrong or out of sequence? Any tip would be great.
