1 - 8 of 8 Posts
Pining for "DMSentra"
P11's don't use struts, just coilover shocks. And, any basic replacement like the GR2, AGX, EXCELL, or any others that are the same dimensions as stock are the ones I was talking about. To lower 2" you really should use a shorter shock that has a higher damping rate to match the higher spring rates that should go with it.
Discussion Starter · #8 ·
what would u recommend ?
1 - 8 of 8 Posts
