as the title says, my fan (vent) only comes on at the second level, third, and forth, nothing at first. it has been that way for quite some time but i never bother to fix it and since i found this forum i decide to ask you people. has this happened to any of you? is it because of a bad switch? how much to replace? thanks much
It is your blower motor resistor that is bad. It is very easy to replace. Pick up a new one from the dealer. The resistor is located under the passengers side of the car. Under the glove compartment. You need to stick your head under there and you should be able to locate the resistor.
If you 'fan problems' on the search function of this website, you'll see more threads on this subject. It is a problem that has come up a few times in the last couple of months.
Hope this helps!
If you're borassic, skint, or broke then you can usually fix the resistor with a soldering iron, the solder on the board usually deteriorates with the heat dissipated at low fan speeds.:cheeky:
