1 - 19 of 19 Posts
I'm planning on swapping an Avenir and going the JWT ecu route. I'm under the impression that the ecu/maf should match up. Since I'll have a G20 ecu reprogrammed to a DET, which maf should I use? Avenir? Or do I need to get a Z32 or cobra and have them program the ecu to that? I'm assuming I can't use my stock de ecu. Let me know.
Boosted & Stanced
depending on what program youre getting for it really, but its def gonna be a US maf. Since its a reprogrammed G20 ECU, then its going to be the G20 maf, considering you didnt have them change the maf program.
Discussion Starter · #8 ·
ERIKbronx said:
Or buy my bored out 53.5mm stock maf from me, for added hp.
http://www.g20.net/forum/showthread.php?t=58607
Yes...that's a possibility. Does JWT have a program for a bored out stock MAF though? It seems like it might be kind of hit or miss depending on how precise it was bored...
Or do they just program the ecu for a stock maf and this gives you some added safety/headroom?
Prince of Joy
The 4 bar program is for stock 370cc injectors. The Cobra MAF is good up to ~350whp. Not sure what the bored stocker is good for (maybe 300 whp?). All you'd need to do is buy the MAF, an adjustable fuel pressure regulator, and let JWT know in advance so you pay for programming once instead of a second time if you upgrade.
Then you can run whatever boost you want, even stock, right from the start.
- Greg -
Discussion Starter · #13 · (Edited)
Thanks for the info Greg. Erik - let me figure out what I wanna do. I may take you up on that, because I don't plan on ever going higher than 250whp. (I know, I know...famous last words, right?)
Edit: So since I'll be going the JWT ecu route where you can't tamper with the tuning, you just adjust the afpr in accordance with the amount of boost you're running? I plan on running stock boost to begin with, but maybe turning it up a bit later. I'd need a boost controller too I assume at that point. Any thoughts on a manual vs. electronic boost controller?
Prince of Joy
No... you tune the base pressure to 3 bar (~43 psi) or 4 bar (~58 psi) depending on what program you are running. The ECU controls the injector pulse automatically based on the signal from the MAF. All you do is adjust your boost controller and the ECU takes care of the rest.
- Greg -
1 - 19 of 19 Posts
