I regrounded my MAF a few months ago. I cut the white wire going to the MAF and took the wire going to the MAF side and ran it directly to the battery's negative terminal. I left the other end of the white wire unconnected.
I have had a weird rough idle problem that leads to an occasional misfire at idle.
After not being able to solve this problem for the longest (putting new o-rings on injectors made the hard starting problem dissapear but seemed to make this worse) I put the white wire back together and left the other end of the white wire disconnected. I am confident that the white wire to the MAF was grounded correctly though.
The car seems to run ok NOW, but the misfire is elusive in that other things I have done seem to cause it to go away for a while.
I have heard that the other end of the white wire goes back to the ECU and serves as a ground reference.
Could not connecting the other end of the white wire have caused this?
Thanks
Thanks
